Hey fellas, so code 210.12(D) basically says if I modify, replace, or extend a branch circuit (dwelling) I have to install arc fault protection. With the exception that if its under 6' its not required, basically so we can just change out a panel or fuse box without racking up a ton in cost.
So what happens when I move the breaker panel 20' away to make way for an addition on this dwelling, fully prepared to install arc faults because I know I need them, and they don't work. First 3 circuits I attempted the afci breakers (SqD) they all tripped. I'm connecting new 12/2 w/g romex to 1970's 12/2 w/g romex so it's not like its knob and tube at least. And even tried an existing circuit that reached the new panel and won't hold the afci. I can't tear apart every light and outlet in this place to hunt down a ghost I may never find. Is there anything else I could try here that I'm missing or does a guy just kind of say hey at least I tried.
There is one saving grace to this is a lot of the house is going to get remodeled so I'm hoping the opportunity to install new circuits from start to finish, then I know my afci will work... But some of it might not....
