Stops operating because of a fault/failure or because of a command to stop? If a fault, what is it?
With the VFD?
We can start with
Is the VFD correctly sized & programmed for the application?
What's the startup ramp time?
Does it usually start when unloaded?
Is the "backstop" some sort of ratchet or does it need to be disengaged like a brake? (Is that happening?)
If you disconnect the auger from the motor, will it start/run?
Assuming the VFD is there for a reason, I'm not sure a bypass contactor would be useful in this situation.
Soft-starts often have bypass contactors since they're used for starting but not speed control, so you can bypass them once the motor is running (there are several threads on the forum here about bypass contactors).
