Frank DuVal
- Electrical Contractor, Electrical Engineer
So you think the cut completely floor joist has been "repaired" by some load path?
Yes I can see that, now that I look more closely at the picture. Crazy.It was definitely the flue pipe from the gas furnace...in the room right next to my kid's bedroom. You can see the double wall pipe B-vent pipe the dislodged piece is going in to.
Duly noted. I stand corrected.It's a 4-11/16" box. Note the cover screws are away from the corners.
Quick question… why does it matter which side of the top is up?It's a 4-11/16" box. Note the cover screws are away from the corners.
That was hard to see.Quick question… why does it matter which side of the top is up?
I don't understand the question.Quick question… why does it matter which side of the top is up?
The picture shows one side of the cover stamped "Under Side".Are you asking why the cover plate has only two holes, or why one is a slot and one is a keyhole?
Beat you to retiring. Would tell contractor & homeowners that I have an agreement with Doctors. I do not work on abortions and they do not perform any electrical work. A contractor wanted a quick fix on a old super market. To turn luminaries on you had to tap drop ceiling a few times. Went up to the ceiling and found at least 20 points where they spliced BX cable w/o any boxes. Told him they only quick fix was to tear it down. Told him that any qualified electrician would only take on a job like this is to pull every wire out and start from scratch.Found this recently. Red wire had been cut short & buried in the connector. It was live. No end to the sloppy & dangerous junk. I’ll be glad when I can retire. Gotta hang in another 3 years at least.
Like Wayne stated and Oldsparky commented on, the cover is stamped “under side”.I don't understand the question.
'Twasn't me.Now that I look at the first cover the Larry posted, it has a UL stamp on the front of it. I wonder if it also has one on the other side.
We should start checking for UL marks on the nails attached to a nail up box.The UL stamp seems to be placed on the inside face (in other words "under side") of box covers. Which side goes toward the box is obvious on many box covers but not on flat covers, and so they mark it "Under Side".
This post on Electrician Talk by Chris Kennedy mentions it's done that way so that the UL stamp does not get painted over, which makes sense:
https://www.electriciantalk.com/threads/who-knew-1900-4-sq-box-cover.50692/#post-937201
I suppose they could place a UL stamp on both sides, but then they'd might have to pay UL an extra fee for that!![]()
