For EVSA use, on a dedicated circuit, I see no code that prohibits use of a 60 amp receptacle. Mind you I know little-to-nothing, so feel free to correct me.
The thinking is to install a NEMA flush 14-60r in the ceiling. This would mean wiring to the box, even the receptacle, would support up to 48A continuous. All I could ask, even though EVSA's seem to not come with male plugs over 40 amps. Still, I could run to 40 amps or remove the receptacle and hard-wire in 48 amps.
Q1) Is there some code against this?
Q2) Rather than cut an end of an EVSA, I was thinking have a 14-60P to 14-50r plug adapter made, and go from there. Is there any code or stigma against using such an adapter (assuming amperage/connectors/wire gauge is accounted for).
As always, Thanks!
-d
As always, Thanks!
-d
