Hi. Upgrading a service with no ground rods.
Turns out the home owner had several ground rods installed for antennas
not sure of the particulars, I will see tomorrow.
The question is
Is a ground rod a ground rod?
Provided they meet the requirements ...
Can I use/share these ground rods to use as my required grounding electrode ground rods?
From what I understand, the antennas rods he has installed aren’t connected to the panel in anyway
if memory serves me, they would need to be connected to the neutral/ ground bonding point in the panel also ... correct ?
thank you
The question is
thank you
