I live in a country where the utility sends only 2 wires, a phase and neutral. When installing Photovoltaic systems, we usually have to create our own ground for the electrical system. The G of the inverter is connected to it. This ground also serves as the earthing for the Surge Protection Devices.
A particular installer has connected the metal structure of the PV to the same ground. And a couple of his inverters stopped detecting the grid and required repairing. This happened during a thunderstorm.
Was it a mistake to use the same ground for the PV Structure?
I have watched Mike's video about not grounding PV structures, but in this case, how does one protect from current leakage in the metal structure?
Thank You...
Thank You...
