Hello,
I've been brought into an existing project where a 208-wye system was upgraded to 480-volts to incorporate new motor loads. An electrician connected a dry-type, delta-delta transformer to the existing 208-volt system and then things got wild. I'm not sure how the neutral was connected but I assume it was center tapped creating a wild leg on the 208-volt system. In electrical theory terms, what happened when this system was energized?
Any help is appreciated.
