Hello all. So, I was doing some interwebs searching, and found this particular post:
I noticed it was never resolved, and I'm dealing with something similar. Here is the rub. We have installed around 300 LED disk lights / wafer lights / surface mount cans / whatever you want to call them. In three houses now, we have had issues with a slight intermittent flicker. It is a few "pulses" where the lights drop slightly in intensity and then level off. It happens at seemingly random times as well. Sometimes its just a couple pulses. Once I saw that it was 4 or 5 pulses. That is the symptom. Now, a bit more information on this. I think it would be best to organize it as a list.
This happens:
I really wanted to pick some brains on this issue, especially when I saw this recent thread was closed with no solution. We questioned the information that PLCC communicates over 60 Hz. The POCO is putting a power quality meter on the service as well, but their PLCC isn't abnormal, it is there by design. I'm thinking about trying a low pass filter in the form of a signal conditioner rated for 0-400Hz or seeing if there is anyway to stop communications for a bit and see if the problem stops.
I'm interested to hear if anyone else is or has fought this before or knows anything about it. Right now we are following the PLCC line to try and eliminate that as a source of noise. It is the primary and clear difference we see between the POCO in town and the coop. Of course, coop can't do much about it if that is the case, but at least we would know about the issue.
Flickering LED fixtures
Anyone have some experience with namely led lighting from Menards, which is mainly Patriot Lighting. Customer supplied fixtures and after I installing the very first of them I noticed a slight flicker. I continued installing with some other models to see if it was just a one-off problem, nope...
forums.mikeholt.com
This happens:
- With or without a dimmer.
- On multiple lighting circuits on both L1 and L2.
- Voltage variation according to two separate meters on L1 and L2 only show around 4/10 volt drop or rise.
- Across 4 different types of LED disk lights, and at least 10 different types of LED lamps. I personally witnessed it on Patriot lighting 4" LED cans, and three types of 6" disk lights, as well as both standard E26 base LED lamps and LED candela-type lamps in a chandelier.
- Even when only a single disk light is the only light on in the house (lighting wise).
- This only happens on our local rural power coop. It does not happen in town.
- I personally terminated the service equipment and the branch circuits. I also went back through to verify connections were solid. (The flicker doesn't manifest as a bad connection seems to do.)
- I have confirmed that the POCO in town uses an RF mesh network for their smart meters, and I have confirmed that the coop uses PLCC for their smart meters.
