An hourly outflow of 120kW doesn't make any sense; kW is a measurement of power, not energy. If a system produced 120kilowatt-hours in an hour and its output were constant, that would mean that it had a steady state output of 120,000 Watts, which is an awful lot of power for a residence. A typical large-ish residential inverter might be on the order of 8kW; that would be 15 of them running full out.I am not active in the solar field, so bear with me.
If a home had an hourly outflow of 120 kW, does that mean that the array produced an excess of 2kW/minute (~8A)?
I know production is not linear.
I think the OP means is constant, instead of linear.I don't know what you mean by production not being linear. Power to amps is a linear equation if voltage is constant.
I interpret this as the total produced and not the rate. So, the residence produced 2kW per minute to achieve the ~120kWh?
120 kWh ÷ 60 minutes = 2 kWm
2kWm ÷ 240V = 8.3 Am (using Pf = 1)
Am I thinking of this correctly?
Yeah I'm gonna agree with Carultch that that max hourly output is likely either mislabeled or some kind of error. As I said above, for 120kWh in one hour, that's an average of just under 500 amps. The only 'residential' service I've seen over 500A was for a multiacre compound with multiple buildings, and it was three phase! So either it wasn't really 120kWh, or it wasn't for one hour the way 'max hourly' sounds like.@jaggedben ben Sorry about the kW instead of kWh.
I received this picture of a report from a colleague. The question asked was, "what is the amperage out?" This is a residence, so 120/240.
@Carultch - correct. Constant.
