When I bought my home there was a separate structure with a subpanel. The panel supply had no EGC, the subpanel had it's own grounding rod, and the neutral bar was bonded to the ground bar.
I have now extended the walls of that once seperate structure to form an *attached* garage.
So I know I need to pull a new supply with an EGC, and unbound the neutral from the ground bar.
Question is, do I keep the ground rod already installed at the subpanel connected to the unbound ground bar in the subpanel?
It is my understanding that since the subpanel is no longer in a separate structure it doesn't *require* a ground rod of its own but is their a reason I wouldn't want to leave it connected?
THANKS!
THANKS!
