Service upgrade
nickelec
US
Looked at a service up grade today. First time I seen a 120 service in a while. Pretty clean and I. Good shape. Can any of you old timers guess an age? I'm assuming original to house and original fuse maybe 40s?50s?
Sent from my SM-G986U using Tapatalk
Not sure of the service but that particular meter is 1940-1954.
The JA and JS series used the “new” alnico magnets.
guess what they were made of…
Real question?
ALuminum, NIckel, and CObalt
That's for a residence?!
No 240 loads obviously.
Is it just for a common space or something? Lights and receptacles?
I was surprised to see you say it was a house, but I guess if all the heating and cooking is combustion of some sort then 120v service is possible.
How common was that?
Rob G
In the olden days, existing houses were electrified with a single 30a 120v service, often with both conductors fused.
The fused switch in the pics has the line incorrectly fed to the bottom*, in addition to the paralleled small conductors.
* Unless that single fuse is the entire service for both meters, which it appears to be as I look more closely.
I have seen similar with a screw for n fuse. My first as an apprentice. I was like wow that's cool. All gas and a few lights and couple of recpticals all knob and tube. As a journeyman I have built 120v service for traffic lights and some pole signs. Now pole signs need a 400 amp service.
My have things changed over the years.
In 1978 when I first moved to NC I remember seeing a 30 amp 120v service. The overhead came into the attic into an open single fuse block. I can't even remember where the meter and panel were. I had seen a few back then but I haven't seen one since then
Rob G
It was very common around here.
In the early 80's as an apprentice and then first year JM I must have upgraded between 18-24.
One town managed it's own power. All the underground services were 120/240 almost all the overheads we're 120.
If the customer didn't want to pay for the underground they kept them at 120.
We did quite a few 120v 200amp services in that town.
It was one of the more upscale towns 12 miles or so west of Boston.
