Mainly panelboards but also any distribution equipment. Does any standard exist or guidance on when equipment should be replaced if it’s too old? As a contractor, Is there a certain number of years or other indicators that would cause you the need to replace in order to warranty your work or just feel comfortable about it.
I have looked at ashrae guidelines for mechanical equipment just to get an idea. The state school commission has 30 year as a mark to replace equipment no matter what if they are involved in funding.
Does availability of compatible breakers come in to play?, We typically replace federal pacific equipment no matter what is there any manufactures or styles that are on a list of need replaced no matter what for you.
Thanks in advance for any input I wish there was something concrete to battle “unless it doesn’t meet code we don’t want to replace it”
My standpoint is from a designer in the office where field data is limited to what you can without a screwdriver in most cases, no opportunity for testing prior to the start of construction.
