WA_Sparky
Electrical Engineer
- Vancouver, WA, Clark
- Electrical Engineer
Just to clarify this is not a post seeking assistance on a DIY project. Any work that may be done will be performed by a licensed electrician, I just cannot wrap my head around identifying the problem.
So my Jacuzzi went out a couple weeks ago. Whenever i press the on button nothing works. Checked the breaker, wasnt tripped. Flipped off and on just to check. Still doesnt make a sound or anything when i press the button. Checked power at the jacuzzi simplex receptacle and theres no power...
Is it more likely that the simplex receptacle burned up or the breaker is malfunctioning in the "on" position?
If it helps, leading up the "no power" event it did seem like the pump was humming for a few seconds prior to turning on. Could that be a sign leading up to the issue? Possibly a locked rotor state that caused high current. Breaker is 20A/1 wire is #12, wondering if receptacle internal components got destroyed before the breaker tripped? Or possibly, but less likely, the original EC installed a 15A simplex on a 20A circuit.
Thanks in advance
Thanks in advance
