Hello all, there are multiple rooms on the first and second floors of this circuit. After tracing, it is lights and plugs only. I was able to trace and isolate one hot and neutral going from the basement up into a first-floor wall. I was able to reconnect with the other knob and tubes that were attached previously and got those plugs working. But there are still some plugs and lights on the first floor that are off, and all the lights and plugs on the second floor are off. I found a cubby access area on the second floor but saw no boxes or splices in that area. The Hot and neutral that I Isolated shows a short circuit with my Greenlee ckt tracer and continuity between the hot and neutral with my meter. This house was built in the early 1900,s and the receptacle boxes are too small to have any splices in them, I can only surmise that the issue may be in one of the light fixtures. No old fuse panel exists that I can find. All of the ceiling fixtures are ceiling fans with lights, so I turned off switches to the ceiling fans, on the ones that had switches, to isolate the problem, thinking there could be a short through the motor if the pull chain was in the on position. I am letting the customer know that we may have to take off each fixture until we find a splice where the feed comes in a ceiling outlet box. Any help is appreciated.
