Hello. I have a Furnas 15BE1BBGX173 contactor (for large air compressor) with a defective coil. It is from 1984, 2-pole with a 240v coil which has already had the magnet wire removed from the bobbin. I believe it will work if I can find a replacement coil, or I can rewind this one if I can learn the wire size (probably around #34) and number of turns (probably between 2500-3000). This is for an historic restoration project, any help is appreciated. Thanks.
P.S. Furnas was bought by Seimens but no help there that I can find.
