I have a GE PowerMark Gold wired as a subpanel in our house which will feed another 125A subpanel at a poolhouse. I need to add 2/0 ground lugs to both the neutral bar and the ground bar. I picked up a GE lug with the tabs that insert under the screws in the existing ground and neutral bars but the width of the tabs are too wide to get into the screw holes. The holes are approx 3/8 oc.
One option I have considered was using a dual ground lug that screws down from the top. The other is the one above with the two tabs that are placed under the screws in the existing ground/neutral bars. I have not been able to find any compatible with what I have. They need to accept 2/0 and be sufficient for a 125 amp circuit.
Can anyone offer suggestions as to the best method to use and provide part numbers/sources for what I need. I was going to contact GE but they are so large that I could not find a contact for the electrical panel division.
Thanks,
Thanks,
