I'm doing as much research about it and there seems to be not much on the internet about it.
In newer model elevators when an elevator is accelerating downwards by gravity, it will generate the energy to miscellaneous loads by using regenerative drives rather than dissipating it as heat traditionally.
The issue is when you connect the elevator to generator, the energy will go back to the generator and it will cause damage to it over time. One known way to counter this would be to install a load bank... but even if I did, how will that even work? How will the energy know to go to the load bank rather than the generator?
I found this article which was actually a little helpful:
https://cdn2.hubspot.net/hubfs/2004...s-of-regenerative-elevators-on-generators.pdf
