Fred B
- Upstate, NY
- Electrician
Is there a simple motor control that can synch multiple motors to operate at same rpm simultaneously?
depends on how synched it needs to be and how you want to accomplish the synching.Is there a simple motor control that can synch multiple motors to operate at same rpm simultaneously?
Guess it depends on what you call simple as well.depends on how synched it needs to be and how you want to accomplish the synching.
most VFDs have a follower function where you can take an analog output from the drive that is the master drive and feed it to the next drive.
or you can have a master encoder that all the drives look at and follow.
I suppose the simplest is to just turn them on and say they are synched. But, in context, I suspect he wants a little more control than that.Guess it depends on what you call simple as well.
I wouldn't call even a basic on/off VFD setup simple compared to across the line contactor for controller method, though it may be about same difficulty level when it comes to how do you connect it for simple on/off control method.
I would think simple induction motors would be harder to synch, but at same time more forgiving because they might allow more margin for slip than wound rotor type motors. That slip will still end up being inefficiency and ultimately given off as heat though.I suppose the simplest is to just turn them on and say they are synched. But, in context, I suspect he wants a little more control than that.
