CaptKarnage
- Milwaukee, WI
- Electrical Engineer
When putting together an electrical panel for US 240V residential use (in this case a generator transfer switch), what is the required separation between hot and ground and hot and neutral?
I can't find this in NEC (I guess not in scope) but something has to determine what is acceptable. Obviously you can't have a short across them, and you need to maintain some distance between them in case of overvoltage / arcing. Is there any US regulation or body (e.g. UL) that uses IEC 61439 in this case, or is there a comparable US standard to guide in building the panel?
