mark32
- Currently in NJ
Hello!
I went to a friend of a friends house today as she was complaining about the one year old led lights in her kitchen not completely shutting off. Initially I thought that the dimmer that controlled the lights was an older one with a locator light, but no, it was a newer "CL" Lutron Diva. Since I was there, I swapped it out with the new Diva I had brought, but the lights did in fact continue to glow when shut off. For the heck of it, I replaced one of the existing led trims (Commercial Elec) with a Halo one, and not only did it still glow when shut off, but it began blinking on and off as well!!?? Details about the job, there are seven old work recessed housings, the power is in the ceiling as there is only a single 14/2 bx going to the switch. Gone is the center light, which means there is likely a buried splice somewhere up there. (No attic access here) I'm guessing the dude that installed the recessed housings, and likely buried the splice, somehow botched the splice, allowing some voltage to get to the lights regardless if the switch/dimmer is off. This lady is out of my typical work area, so I do not have plans of going back anytime soon to troubleshoot, too busy closer to home. This is mainly for me to understand what could be the culprit here. Thanks!
