Pceja007
- San Francisco
- Electrical contractor
Hi all,
First time post.
I am performing an installation at a convenience store in a mixed use building. Commercial on the lower floor, residential units above. There is a 400 Amp service coming into the building landing at a 400 amp disconnect. This 400 amp disconnect feeds a 225 amp disconnect about 3’ away. The 225 amp disconnect feeds the 3 apartment meters and disconnects, along with the existing meter and disconnect for the convenience store. I am attempting to increase the service capacity of the convenience store to 200 amps. I’d like to install 2 feeders off of the 400 amp disconnect ( one for the existing 225 amp panel and one to a 200 amp meter and disconnect panel for the commercial unit.
I have 2 questions:
1) can I increase the capacity of the convenience store to 200 amps or only 175 amps ? Given that there is already a 225 amp panel in service.
2) can i go to the meter and then OCPD from the feeder tap at 400 amp disconnect? i know the code says I need to land on a correctly sized OCPD, would going to the meter first violate the code ?
any useful help greatly appreciated.
thanks
First time post.
I have 2 questions:
thanks
