mark32
- Currently in NJ
Hey Guys!
A friend of mine is a handyman, but was asked by a customer to change out a motor on some machinery in a machine shop, which he did. Afterwards, all seemed well enough, but either he or the shop foreman decided to change the contactor's coil. At the same time, for whatever reason, my friend switched around some of the conductors coming off of the secondary of control transformer (208 to 120). So, while holding the contactor in his hand, he hits the start button, the contactor engages, the motor runs, everyone is happy. He then goes to screw the contactor back into it's enclosure, and the motor instantly shuts off as soon as the contactor touches the enclosure. Then, with the contactor floating, he hits the start button, the motor runs, but all shuts down again when the contactor makes contact with the enclosure. He took a sheet of rubber and sandwiched it between the contactor and the panel and all is well for now. I may look at the install in another week or so for him, I'm assuming the control circuit is opening but can't understand why. What do you guys think could be causing this to happen?
