dylanmitchell
- San Diego
- Historic (Old and outdated) Home Renovation
Looking at vacuum cleaners and noticed a difference in power use for EU/ UK models vs US models. 220-volt vacuums look to use fewer amps. Same theory as my 240 volt AC using fewer amps vs a 120 amp AC unit. EU energy-saving vacuum rules but it looks like you could have a very powerful vacuum and tools running off 13 amp 220 volts vs the 15 amp 120 volts in the US.
Most US household vacuums, shop vacs, and dust collectors max out around 1200 watts or 10 amps. My vacuum runs at 1200 watts, plus 175 watts for the power nozzle/ brush head or about 11 amps. I looked at Henry vacuums the older EU vacs ran 1060 watts or under 5 amps newer 680-watt vacs run about 3 amps. Absent energy regulations, it looks like you could run a 2,400-watt vacuum that's about 11 amps off a standard 13 amp 240-volt circuit. Be a powerful vacuum. Are UK/EU 220 volt appliances more powerful? I've heard 220-volt tea kettles heat up more quickly.
