3Ph Transformer secondary voltage question
scrubbin
PA
Maintenance Tech
Hello, I have a SQ-D three phase (Cat # 30T6H) 480v Primary to 240v Secondary transformer. I would like to lower the secondary voltage to close to 220v. The transformer has 480v primary voltage connected to the number 3 taps. So if I change the 480v to a different taps would I safely be able to get closer to my desired 220v? and which taps would I connect it to?
Do you have a photo of the nameplate? Using the highest voltage taps on the primary will give you lowest voltage on the secondary.
