What's up with the Siemens 220v 20a gfci stocks?
Oh. You said you can't find any stock
But you meant you can't find any cheap.
Those that have any know they can sell over the normal price and the demand is high enough that they still will sell.
Was in local "farm supply store" yesterday. Noticed the pet food aisle that normally has pallets of food was nearly empty, luckily still had the product I was after though. Water softener salt, one the items I was planning to get - absolutely none, motor oils and other lubricants/hydraulic fluids - lots of empty shelf space in that section. IDK if they happened to sell out and more is coming or if there is a supply issue with those items.
I need some power factor capacitors to put on irrigation wells - replace failed ones from past season, been on order for a while now. not sure exactly why on those.
Square D GFCI/AFCI's - sounds like stock is generally available if you don't mind the conventional pigtail neutral versions, but plug on neutral versions they don't know when they can get certain ones. Dual function seems to be the worst one on availability.
For sure.
Two years ago $65 was high
Now $100 is a good deal
I prefer the ones with pigtail because I do a mix of new construction and remodel. I have yet to do a remodel job with a PON panel. Pigtails work everywhere
For sure.
Starting to get to the point where PON has been around long enough you can have panels that accept PON in remodels, at least with Square D panels.
