I have a 240/120 3 phase high delta panel (4 wire system) that is feeding things like 5-10hp motors, the load is low on this panel but i need more circuit breakers to feed 120v receptacles throughout. I plan to add a sub-panel 240/120 single phase fed from the 240/120 3 phase panel. Taking two hot wires and the neutral and ignoring the highleg. So a 2 pole breaker in the 240/120 3 phase to feed the 240/120 1 phase sub-panel to feed around 20 circuits 120v circuits receptacles. Is there any issues with this setup? Will this cause an inbalance in the system?
Thank you
Thank you
