eufemiano
- philippines
- technicAL
Hello Fellow mates,
I have a question, what are the pro's and cons of using 2 wires with half the size of a single wire ? I know it is uncommon, but is it possible? For example you need a wire with a size of 50mm2 but you don't have that and so, instead as an alternative you use 2x 22mm2 wires. would it be the same ?
thank you.
thank you.
