I'm working in a building in NYC that has 2 existing fire alarm panels being fed by (1) 3-pole 30A service switch. 2 separate taps at the service conductors are performed and then terminate into that 30A switch. 2 out of the 3 poles of the disconnect switch are used to power the 2 fire alarm panels (1 pole is dedicated to 1 fire alarm panel) meaning there are 2 live wires and 2 neutrals going into the 30A 3-pole switch.
This is the weirdest setup I've seen. Is that even allowed or does each fire alarm panel need it's own dedicated disconnect switch?
