mtnelect
HVAC & Electrical Contractor
- Southern California
- Contractor, C10 & C20 - Semi Retired
You are correct ! ... Heat Pumps don't provide heat like gas, it's a more "Gentler" and gradual style of heat. The major advantage of ductless mini splits is you don't have to service the whole house, only the room your in.We have places using ductless with no backup heat or if there is other heat it is not associated with the ductless system in any way - often just spill over heat from an adjacent area at best. And we get to zero and below every winter, usually not for more than a few days at a time, but is still cold enough that those systems would still be needing to operate, and for the most part they do.
All air to air heat pumps you see here, ductless or not, have defrost function of some sort, they simply don't work if the outdoor coil is plugged with ice.
The secret is to do a "Heat Load" engineering study, not the "Rule of Thumb" based on square feet. See attached example.
