Does such an enclosure exist?
Todd0x1
CA
Looking for a deep 3R pullbox that has a flange around it to be mounted half in/half out of a wall. New construction, have some conduits coming up out of the ground that need to get into a wall then travel up the wall. No room in the wall for 90s and the interior side of the wall won't be accessible. I'd use 4S box inside and an extender outside but its too small. Need something like 6" wide and 12" high.
Can't you just build a flange around the box, i.e frame around it.
That's one idea. I suppose I could weld a sheetmetal flange around the box. It gets embedded in stucco and still need to stick out enough for the conduits to enter the bottom of the exterior portion.
I've always found a way to use framing, strutt, or even a "caddy" adjustable bracket to do so & never needed a flange. Also maybe you can alter the conduits via bend to make this work. Tuff 2 say without seeing the exact install. If not physically possible I would talk to the framer or gc & explain the situation. This has worked good for me in the past. However, these day's it hard 2 find a good gc that will work 2 help u. Sometimes framing can be moved or altered. Also in some cases a wall can be furred out to allow more room. Good luck.
Sent from my SM-S906U using Tapatalk
A "caddy" 2 or 4 hole L bracket bolted to the box & framing works well also. U can position them so they won't interfere with your conduits.
Solved, they said I could move over a couple feet which gets me into a furred out wall with room for 90s I can stub out the exterior side.
