electronman
- G.R. MI
- Electrician
Working in a strip mall and concrete cutter made numerous cuts in the floor for the plumber to rough in 3 bathrooms. When all the concrete was removed it revealed 3 feeder conduits that had been cut through in multiple spots. Most were cross-cut and 2 were parallel cuts about 12" to 18" long. Two of the conduits were not energized but one was, and remained energized (the furthest one from the cuts, of course). I decided to cut open the top of the conduits to get a better look at the conductors and they were not damaged. I'll have to do this at each cut. I've used PVC repair kits before with good success but they're pricey and the conduits are packed close together with no way of spreading them apart. Any ideas? I know the only right way is to pull conductors out of all 3 to inspect them, replace all the PVC and re-install the wires. I thought I would see if anyone has been through this and what other options might be.
