Relying on a device to pass neutral and power?
Bbaehre91
Lansing Michigan
It grinds my gears when i see 2 wires in a box and someone just puts the wires on the receptacles instead of making a joint. I thought I had read at one point it was against code to rely on the device to pass power. I can’t find it. Does anyone know just curious?
I don't recall any such rule. What would be the point of such a rule?
There is a rule that you have to be able to remove the device without opening up a ground connection to another device so grounds have to be pigtailed.
Most devices have been tested and listed for multiple connections using the terminals so don't let it worry you to much, it is safe.
I prefer to wire nut two wires but in smaller boxes this often brings up the cubic inch box calculation so then you have to bring both white & black wires to the receptacle. We had a lazy sparky who more then once ran a total of 9 wires to a 125 volt duplex spec grade receptacle that had pressure plates allowing 1 screw to secure two wires. I was taught to identify the black energized conductor with a wrap if tape.
I don't understand this. Isn't the conductor some color other than white already?
On bigger jobs, I'll identify cables with two-letter abbreviations (FI, FO, SL, TR, etc.) inside boxes with a Sharpie.
It's rarely an issue, though, as I make up my boxes at rough-in, hooks on the wires and positioned for each device.
feed in
feed out
switch leg
traveler
I finished a house behind a guy who stripped and hooked all the wires. I didn't know it until I grabbed the center of the roll and yanked it out of the box.
Fish hooked my index finger and ripped it open about 3/4 inch
I wanted to grab him by the throat and squeeze
Sorry about that. :confused: I guess it's better to rough and trim your own work.
What difference would it make?
Well it would in a switch box with a 3-way switch leg and travelers, load or power in. Also, if there is a GFCI receptacle, you need to know which wires to put on the line side.
I don't use tape or mark them, I have a way of placing the wires that I go by. Things like the KO closest to te stud is for power, I wrap wires around each other a certain way also.
My system is usually anything not marked at all is "line" or "hot all the time". Anything marked is marked with the function that applies. Marking a cable with "load" would be the switched load in a switch box, or maybe the load side of a GFCI. In boxes with multiple switches, cable would be marked with name or abbreviation of whatever load it supplies, all "line" cables still unmarked.
Box with 2 wire in, 3 wire out or vice versa on other end of a three way circuit - very likely no markings at all - I know what it is. If someone else has to finish my rough in, say I got fired from the job, why would I care? Let them figure it out. If I had an employee, hopefully they eventually learn, if they can't learn they probably aren't going to work out in long run. If they are somewhat temporary help to begin with I probably won't have them making up such connections, will leave them with the simpler line in - line out receptacle outlets while I work on the boxes with more complex connections.
