I have a 400Amp single phase main panel that is feeding multiple buildings. One of the buildings is being renovated and it requires a 200amp breaker. The current panel does not support a 200 amp breaker (it supported a maximum 150 breaker). The manufacturer of the panel (square d) rep recommended adding an enclosed breaker outside the panel and taping into the main panel lugs. I presume the tap will be after the 400amp main breaker. I do not see any code issues or setup issues with this installation, I wanted to ask here if there are issues I might not be aware of.
Thank you
Thank you
