Hi I work in Ohio and we have a 13.2kv system. 7,620v phase to ground, this is a wye system. On a single bushing transformer we connect the transformer neutral tail to the system neutral and the pole ground, the neutral acts as the return for the system. If the transformer neutral is only connected to the pole ground and that connection is broken, what voltages could a person get if her completes that ground circuit? This is a 50kva single bushing 120/240 transformer. Thank you
