electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
I have 2 runs of 2 1/2 EMT I need to insert a wireway into. Everything on both ends is tight and would be real hassle to get enough play to get the EMT connector into the wireway after I cut out the EMT's to the width of the wireway. What is the best way to do this? I come up with the following options:
1. 2 piece EMT connector. Problem is I don't think anyone makes one in a two and a half....
2. This thing:. It's 2 in which is not ideal I could reduce to it I think it would meet conduit fill as a nipple
3. Threaded coupling flush with the wire way with a chase nipple threaded into it from the inside of the cabinet.
4. Similar to three, but use a running thread nipple and thread the lock nuts in as I go.
Whatcha think?
Whatcha think?
