MKerrigan90
- New Jersey
- Electrician
Installing a hot tub.
Hot Tub Nameplate:
240v
Circuit Breaker: 60 Amps
Current Draw: 45Amps
60 Amp breaker in the main panel will feed spa disconnect with 6/3 romex located on the outside wall of the house. A 60 Amp GFCI breaker will provide the branch circuit to the hot tub with 2 #6 THHN with #10 grounding conductor in pvc conduit. My question is about the 6/3 romex, does 240.4(b) apply? 6/3 NM-B at 60º is 55 amps.
Hot Tub Nameplate:
240v
