I am working on short circuit calculations for a system. There is an HVAC unit (nameplate attached). I did verify (Unit Power Supply) the cable and upstream protective device do meet the minimum circuit ampacity and max circuit breaker size, respectively. I have the following questions about the nameplate and how should it be modeled in the study software :
1. I understand there are motors for compressors. Will this HVAC unit be modeled as an induction motor in study software?[/li]
2. How to determine the HP/kW rating of this unit from the nameplate?[/li]
3. Nameplate shows TWO systems on the nameplate what does it imply? Is one backup to another? [/li]
