Small 2HP motor had some type of failure or overload. After removing motor from the machine to troubleshoot, it was noticed that the shaft is locked up to the point that I can’t spin it with my hand while completely uncoupled to anything else. Also, one of the phase leads in the motor seems to be open circuit to the center wye point, so that tells me one of the windings probably burned up.
I logically want to say that whatever is internally causing the motor to be seized is the root cause, and then that made the winding burn up. But, is it reasonable that it was the other way around? Could there have been some type of external OL from the connected machine onto the motor, then the winding heated/failed/burned, and then that melting action “glued” some parts together internal to the motor that’s causing it to be seized? I was thinking it would have to be pretty catastrophic heating of the stator to melt something with the rotor that would cause it to be stuck, but maybe not?
Side note: the OL dial was set way too high, so it had no chance of opening first.
