Alwayslearningelec
- NJ
- Estimator
If you has this scenario where you had l6ight poles, 1st @ 100' from source, 2nd 300', 4th 400' and so on to the last on @ 700'
1. If you had to run say #1's due to voltage drop and all those lights were on the same circuit you would have to bring the #1's throughout the entire run all the way to the end correct? You would then splice down to a smaller conductor at the fixture.
2. What would be the best way to down size the #1 conductor to terminate on a 1P-20A breaker?
Thanks.
And maybe I'm not figuring this correct. I'm plugging into VD drop calculator.
Each light draws ~1amp but for the load rating input I'm putting in 16A( 80% of the 20A breaker).
www.jcalc.net
Thanks.
AC and DC Voltage Drop Calculator NEC
The Voltage Drop Calculator implements the USA NEC Code. It includes Voltage Drop Formulas and Examples of How To Calculate Voltage Drop.
