Brianest1978
New User
- Phoenix
Can someone point me to the NEC code that states it's OK to use "waterproof" wire nuts in an underground standard pull box with 480vac?
Or point me to the code that states it's OK to use standard wire nuts with electrical tape in an underground standard pull box with 480vac?
These locations are considered "wet" obviously.
The reason I ask is that I'm constantly seeing EC's use the above for splicing and I'm constantly finding these are corroded and/or burned up. To me, it's dangerous to use the above wire nuts in these locations. "Sealed" connectors suc as epoxy bags should be used...
Am I alone in thinking this? Thanks for the help!
