Alwayslearningelec
- NJ
- Estimator
When you land a sizeable lighting and power job($500k and up) what are the first few tasks a PM needs to do?
get drunk and celebrate?When you land a sizeable lighting and power job($500k and up) what are the first few tasks a PM needs to do?
get drunk and celebrate?![]()
Thank you!!Have a pre-construction meeting with estimator, field supt, job foreman. Go through all plans, specs, quotes, schedules.
This is the time to flush out any mistakes, omissions from the estimator, bad quotes that don't cover scope or price escalations.
The estimator needs to break the job down into work codes for management, set up schedule of values for billing, write PO's for quoted items and subcontracts, etc....
...ain't that the truth!Wonder where you screwed up on the bid...
LMAO!!!Wonder where you screwed up on the bid...
does your Preconstruction/estimating dept write POs and subcontracts?Have a pre-construction meeting with estimator, field supt, job foreman. Go through all plans, specs, quotes, schedules.
No the pre-con meeting advises the PM of who's quote you used in the estimate (fix, gear, subs, etc)...it's up to the PM to do further vetting of quotes prior to writing PO's.does your Preconstruction/estimating dept write POs and subcontracts?
Similarly, what are that department’s duties to the Contract?
