Alwayslearningelec
- NJ
- Estimator
When you guys need to bend or offset horizontally underground and your using PVC elbow( not RGS) say 2"-4" do you use factory elbow or bend the PVC with "hot box"?
Thank you Roger appreciate the insight. What are the jigs for?Depends on the number involved. If it's just a few it is cheaper to use factory elbows, if there are a lot it can be cost effective to field bend. We would put a helper on it for maybe a day (and at times many days) bending 90's. We would set up jigs on a plywood table.
Weed burner as long as no inspector is around the cornerWhen you guys need to bend or offset horizontally underground and your using PVC elbow( not RGS) say 2"-4" do you use factory elbow or bend the PVC with "hot box"?
where in the code does it specify what tool can be used to bend PVC pipe?Weed burner as long as no inspector is around the corner![]()
A wet rag will set the pipe too.When I say jigs, I mean we would bend 90's with EMT and screw them down to the ply wood for guides when we heated the PVC, we would have a water hose to cool the PVC down after laying it between the EMT, that sped up the process.
Exactly. But some people tend to frown upon it.where in the code does it specify what tool can be used to bend PVC pipe?
352.24where in the code does it specify what tool can be used to bend PVC pipe?
Thanks again. It's hard for me to picture what your describing. Don't worry, thanks.To clarify, we would space the EMT (2 pieces) the proper distance apart (the width of the PVC) and offset them, we could do 4 at a time
I'm not doing a very good job explaining it. For 2" PVC start with a 4 X 8 piece of plywood, bend a short 90 on two pieces of 2" EMT about 4' long, drill holes through the EMT on the 90 end and the tail piece and screw one piece down to the plywood close to the top long edge.Thanks again. It's hard for me to picture what your describing. Don't worry, thanks.
Its called a hillbilly hot box here.. make a quick trench in dirt, put bits of wood in, pour primer on it and royally screw up the pipe.Weed burner as long as no inspector is around the corner![]()
