I-learns
- South Dakota
- Student
Something I saw causes me to revisit the theory of communications systems grounding. Isn't a reason you do not bond an antenna to a subpanel and instead bond to the main service GEC point so that you can reduce the chance that different voltages will set up throughout the building distribution system as the voltage from a static/strike drops while it takes the route to the grounding electrode system? If so then wouldn't it be a good practice to keep the antenna discharge unit seperate from the enclosure containing the actual radio, so that there won't be a connection from the antenna's coaxial shield to the equipment ground in the same enclosure that comes from a 120V power source for the radio?
