RLMJR
- Electrical Engineer
I am currently handling a project (replacement of pad mounted transformer). I um unsure if i need to put overcurrent protection (ECB) to protect the secondary conductors. The existing system goes like this : existing 500 kva , 13.8kv to 480/277V pad mounted transformer located outdoor with secondary conductor two sets of 500 MCM THHN (without over current protection),- connected to normal side of existing 600 amps ATS (outdoor) (open transition - not a service type ATS) (note: emergency side is connected from 300 kw generator via 600 amps breaker (outdoor) with 2 sets of 500 MCM also) : the load side of the 600 amps ATS is the connected /supplies the existing switchgear MS- MAIN 800 amps / 1200 amps rated bus.).
All are existing condition and my task is to replace the leaking defective transformer with same rating 500KVA pad mounted transformer, but i was told by my supervisor to include in the scope to put a 600 amps breaker on the secondary side of the transformer to protect the existing ATS the conductors and the loads. My question is, is this really required ? as i read in article 240.21 c (4) overcurrent protection in secondary side of transformer is not required for outside secondary conductors.
(PS; i want to share a diagram in pdf file for clear explanation but i dont know how to upload a pdf or jpeg in this post) sorry just a newbie here.
Thanks in advance for the answers.
