Darkcustom2013
- PA
- Electrician
Hi all,
Looking for alittle help on the topic. We had a existing corner ground delta delta 45kva transformer that was hooked up in reverse (240-480) feed a piece of equipment in one part of the plant. It was feeding 240v 3 wire 3phase on the secondary and feeding 480v 3 phase off the primary. This piece of equipment was removed and we had the transformer just sitting around.
Someone in engineering order another piece of equipment for 480v not 240v, so they wanted me to hook the old transformer back up. The current setup was a 100A main breaker, disconnect feeding the 240v primary side fused at 80A, secondary disconnect fused at 50A protecting a motor with a FLA of 28A. My question is, when energized I am getting 480V P-P on the secondary but my P-G is 200v-210v on 2 phases and 315v P-G on another phase. Is this normal? or is there something going on?
