Thanks, I didn't know that about heater elements.
I still feel like perhaps I'm missing something.  The 11,520 watts stays constant, so reducing from 240v to 208v results in increasing from 48A to roughly 55A.  Sounds like the load (heater elements) would need to change as well, but it still just follows ohm's law.  I could see if you switch from split phase to three phase (sharing the load on all three), you might divide by 1.73 and then use lower current and certainly the heater elements would need to change to allow the new wiring system.
