mopowr steve
- NW Ohio
- Electrical contractor
I’ve been wondering about what effects may be caused, if any; of the inverters used for grid tied systems, more so on the utility side.
For the past couple years I’ve been noticing a problem with what seems to be with a particular power company over another. In that on new construction homes many times we’re having problems with flickering LED bulbs with what appears to be some pattern and random tripping of GFI’s, and arc faults. And in some past discussions on this forum it’s been said that the smart metering and other communications being sent via the electric lines could be the culprit. As the communication is sent near the zero crossing and that it does affect dimmable LEDs as they are reacting to this anomaly. Now if I install a non-dimmable LED that usually remedies the problem.
So, my question is. Is it possible that solar inverters can cause an anomaly on the sign wave like that of communications either as a malfunction of an inverter or in its normal operation as it seeks to sync with the 60HZ ?
