LOAD
- washington state, USA
- residential electrician
Hi guys, I've had my 02 for about a year, most of my experience is with residential new construction so I still am learning a lot as I go.
Anyways, my initial plan was to do a 240v 70 amp outdoor subpanel at the other end of my parents property for an RV hookup and outdoor work plug. We oversized it just in case we wanted to ever add something else down there (Our pumphouse is down there - as well as some other sheds we maybe wanted power in in the future)
It is about a 230~ foot run which to account for voltage drop I ran 3 runs of 2 gauge copper thwn in pvc with a 6 gauge ground.
However, I have come across a bit of an issue when getting the wire from my crawlspace to my panel. I wanted to use SER and splice the run together in a jbox in the crawlspace, but now I'm having trouble finding SER that is the appropriate size. I could just bite the bullet and oversize the crap out of it, but that's a lot of $$$ and I feel is unnecessary. I tried to conduit up to my panel but I realized it would be a real pain to pull through due to the amount of bends I'd have to do. So, I've thought of one more plan but I wanted to get some additional input to see if it would be ok.
I was thinking maybe I can instead of doing 70amps, I would just do 50amps, forget the future power, and downsize the wire in the crawlspace to nm-b 6-3. But I wasn't sure if that would cause a problem with the voltage drop? If anyone could let me know that that would work, or if you have a better idea, that would be fantastic.
