jeff48356
- Livonia, Michigan
Since the Code now requires ceiling-fan rated boxes installed in bedrooms, does that mean that they finally did away with the option to cheap-out by installing only a receptacle controlled by a switch without any permanent lighting? Or is it written to mean that if the builder chooses to install a fixture box in the ceiling (rather than just a switched receptacle), then it must be fan-rated?
