I’m not sure if I understand your question.Are you trying to use it independently of it's associated equipment?
Yea motor rated switch, I was wondering to know how it practically wired. My Question was about does the switch wire direct to the motor?Okay, how about a 2p HP-rated switch?
I see. Yes The motor comes with transformer. It has 24V output to feed PWM controller. So I can use the 24V to feed the switchTwo conductors down to the switch then back up to the motor? You could get fancier and use a contactor at the motor, 24V coil, small 24V transformer and two conductor low voltage wire down to a single pole switch.
-Hal
